Texalarm
3 messages • Page 1 sur 1
Message par PhZ » dimanche 17 décembre 2006, 11:45
It could be due to the antenna of the anti-ignition device (transponder) in connection with the Neiman key contact, unless battery of the key itself is out of order, but I suppose you already checked it..
I don't believe it's due to your Texalarm.
KIKI
Contact :
Contacter KIKI
Site Internet
Message par KIKI » dimanche 17 décembre 2006, 11:50
:shock: :shock: :roll: :roll:
yes yes, of course.........
PhB
Message par PhB » dimanche 17 décembre 2006, 12:07
PhZ a écrit :It could be due to the antenna of the anti-ignition device (transponder) in connection with the Neiman key contact, unless battery of the key itself is out of order, but I suppose you already checked it..
No, I think it's because the alarm switch instead the original system remote. So if it's out of order, you have to disconnect the alarm wire and connect the wire of the original remote box. I don't know if "BSI" includ receptor or if it's another box . Don't ask me where is this connection, I don't know. May be you'll find it following wires of the alarm. I think you'll find it behind the glove box.
